I am using Umbraco 8.13. I wonder that on a page suppose i have done some changes and save and publish worked smoothly. But if again update and trying to save it will not save.
So i need to reload that node then update and save
So each time a new update needs to reload the node then save.This is very very surprising,i can not commit the client to use Umbraco if Umbraco has these very basic limitations?
Hmm that shouldn't happen. I just tested saving a node, saving again and publishing in v8.13, and it worked fine for me:
Could you check your browser console to see if any errors appear there when it fails to save? Also, be sure to check the Umbraco log for any errors too.
Node not publishing
I am using Umbraco 8.13. I wonder that on a page suppose i have done some changes and save and publish worked smoothly. But if again update and trying to save it will not save. So i need to reload that node then update and save So each time a new update needs to reload the node then save.This is very very surprising,i can not commit the client to use Umbraco if Umbraco has these very basic limitations?
