Yes is a system message but I think that there is no solution about that, because I just saw the relative method Umbraco.Web.Controllers.UmbLoginController.HandleLogin(LoginModel model) and the returned message is a simple english message and not a localized message
[HttpPost]
[ValidateAntiForgeryToken]
[ValidateUmbracoFormRouteString]
public ActionResult HandleLogin([Bind(Prefix = "loginModel")]LoginModel model)
if (ModelState.IsValid == false)
return CurrentUmbracoPage();
if (Members.Login(model.Username, model.Password) == false)
//don't add a field level error, just model level
ModelState.AddModelError("loginModel", "Invalid username or password");
TempData["LoginSuccess"] = true;
//if there is a specified path to redirect to then use it
if (model.RedirectUrl.IsNullOrWhiteSpace() == false)
// validate the redirect URL
// if it's not a local URL we'll redirect to the root of the current site
return Redirect(Url.IsLocalUrl(model.RedirectUrl)
? model.RedirectUrl
: CurrentPage.AncestorOrSelf(1).Url());
//redirect to current page by default
return RedirectToCurrentUmbracoPage();
I think the only solution is that I create a custom login form.
the problem isn't the property name, but the Html.ValidationSummary's messages.
This is my login form (no problem with this)
This is the error I received with invalid credentials (no localized)
As you can see, I received an "Invalid username or password" error message but I would to see that message in italian...but as I wrote, I saw that the HandleLogin method return only a simple text and not a localized text (see above)
If your site is in Italian only, you can translate the message directly in the code.
LoginForm Snippet return english messages instead of localized messages
I'm using Umbraco 8 and I set my website with italian culture. All function properly except the login form messages.
I create a partial view based on the available snippets.
How can I localize those messages without creating a custom login form?
A.
Hi Adriano,
are you referring to the system messages? I think you can solve it by checking the dictionary and adding the Italian translation.
M.
Hi Marina,
A.
You can use https://our.umbraco.com/packages/developer-tools/umbraco-dictionary-metadataprovider/
just create Dictonary in relevant language
Login Login.PROPERTY_NAME = username
PROPERTY_NAME - property name in model
Hi Yakov,
A.
M.
Marina...the Umbraco.Web.Controllers.UmbLoginController.HandleLogin(LoginModel model) is an Umbraco Core method.
I should change the Umbraco Core method and re-compile all umbraco website...unthinkable.
I think that is more secure and flexible to create a custom login form with a custom surface controller to manage the login.
A.
I think you are right need to create new controller for it
Yep...I think so!!!
create your custom controller, don't change umbraco code
