  • Pushpa 14 posts 94 karma points
    Jul 08, 2021 @ 11:54
    Pushpa
    Licensed Courier and Umbraco Forms
    We have licensed courier tool and umbraco forms used in version 7.15.3, can we use the same licensed couier and forms for the umbraco version 8+. Please let me know.
  • Brendan Rice 538 posts 1102 karma points
    Jul 08, 2021 @ 12:00
    Brendan Rice
    The license for forms works and I assume Courier will as well.
    As far as I know the licenses are per domain so you should be covered
    Jul 09, 2021 @ 10:21
    Pushpa
    Thanks for you reply, is courier tool works in umbraco 8+ version?. Please let me know.
    Jul 08, 2021 @ 12:24
    Nik
    Courier doesn't work on Umbraco 8,
    So it would only be the Umbraco Forms license you need to worry about.
    Jul 14, 2021 @ 06:32
    Pushpa
    Thanks for the reply, Umbraco 7+ forms license will work in version 8+?
    Jul 14, 2021 @ 07:00
    Nik
    Hi Pushpa,
    It might, I'm not 100% but it's worth giving it a go. I've not seen anything in the licensing that checks version so you should be okay.
    Nik
    Jul 14, 2021 @ 10:21
    Brendan Rice
    I'm pretty sure the same license works for both.
    Jul 14, 2021 @ 10:29
    Pushpa
    Thanks for the reply, is umbraco 8 deploy tool works only with umbraco could?
    Jul 14, 2021 @ 10:34
