Hello i would like to do something similar but without paging
_contentService.GetPagedChildren(currentPageId, pageIndex,
pageSize, out var recordsCount, filter);
Is this possible? All i want to get is all children that respect the filter and be really quick. i saw that GetPagedChildren accept an IQuery<> parameter so i think the filtering is translated into SQL.
you could just set the page size to something very large, however fetching very large datasets isn't a great idea which is why it uses paging, but if you know there won't be many results then it wouldn't be a problem.
Alternately you could use an examine searchquery to find what you require which would probably be quicker depending what your filter is on
GetChildren without paging and using IQuery parameter
_contentService.GetPagedChildren(currentPageId, pageIndex, pageSize, out var recordsCount, filter);
