Hi our Umbraco Team
How are Examine indexes rebuilt when app is up and running?
I know i can manually go into back office and rebuild.
I just would know if they update on new/update node or on a timing service ?
Dibs
Hi Dibs
Whenever you publish a content item or save a media item, then the corresponding entry in the Examine index is also updated.
So in theory the indexes never need to be rebuilt or ever updated on a regular interval.
Examine indexes are ultimately files on disk, have a look in app_data/Temp/ExamineIndexes (if I remember correctly)...
... if you are load balancing or scaling out server instances there is a very specific Examine configuration to have in place - https://our.umbraco.com/Documentation/Fundamentals/Setup/Server-Setup/azure-web-apps#recommended-configuration ...
Otherwise be careful when deploying your site, not to copy up the Examine Indexes from your development environment!
Occaisionally the Examine files might get 'locked' after a deploy - that's when the rebuild button is handy in the backoffice.
regards
Marc
Cheers Mark,
Just wanted to know confirmation on how index is updated. It did not update when i unpublished a node, but when like you say rebuilt the index from back office. This reflected in the unpublished node omitted from search results.
Examine index rebuilds
Hi our Umbraco Team
Dibs
Hi Dibs
regards
Marc
Cheers Mark,
Dibs
