Umbraco 8.14.1 upgraded manually to 8.15.0. on Windows 10 Pro and SQL Server 18.9.2 and everything seemed fine. Viewing existing pages seems to be fine. When I try to edit and save or publish a page the button circle keeps spinning and the page is never saved to the database. When I look at running processes on the system I see that IIS Worker climbs to 50-60 % which takes the CPU to 100%. I went back to my 8.14.1 code and database backup and everything works fine including Save and Publish.
Is this a bug in 8.15.1 or was I supposed to do something other than copy over the /bin and /Umbraco folders?
Normally this gets incremented as part of the upgrade - but if you copied the folders, I'm not sure this would have happened.
Incrementing the version will ensure the backoffice loads fresh versions of Umbraco's client side assets - so maybe without that the UI is calling an older endpoint in save and publish, and errors (see if there is anything in the console) - and so never completes, and you see the endless button circling?
v8.15.0 does not save pages, IIS Worker and CPU max out to 100%
-Dan
Hi cerdts
It might be a bug, but one thought with manually copying those files is did you increment the client dependency framework version?
https://our.umbraco.com/Documentation/Fundamentals/Setup/upgrading/general#potential-issues-and-gotchas
regards
Marc
