var groups = item.Children.GroupBy(i => i.Value("category"));
@foreach(var category in groups)
<div class="submenu-row">
<div class="submenu-column">
<p>@category.Key</p>
@foreach(var subitem in category)
<a href="@subitem.Value("contentLink")" title="@subitem.Value("title")">@subitem.Name</a>
Any ideas how to render it correctly ? I was trying to render
in the condition , but umraco did not let me to do it. Basically , the main goal is to render every 2 categories in pairs wrapping in a div which stands for rows , but now it's devided on rows for each category ( or i can wrap it in just one big row).
we need pretty much just to start rendering in pairs if it's not "view all" item , simply saying to make render it just a bit differently. hope u understand me ;)
you will need to identify the "view all" link somehow. There is no way to ensure that the "view all" is the only link without a category, so checking for an empty category may not be enough.
Other than that :
var categories = item.Children
.GroupBy(i => i.Value<string>("category"))
.Select(x => new {
Category = x.Key,
Links = x.Select(y => new {
Link = y.Value<string>("contentLink"),
Title = y.Value<string>("title"),
Name = y.Name,
}).ToArray(),
}).ToList();
foreach(var row in categories.Where(x => string.IsNullOrWhiteSpace(x.Category)))
@foreach(var item in row)
<div class="submenu-column should-be-full-width">
@foreach(var link in item.Links)
<a href="@link.Link" title="@link.Title">@link.Name</a>
foreach(var row in categories.Where(x => !string.IsNullOrWhiteSpace(x.Category)).InGroupsOf(2))
<p>@item.Category</p>
Rendering Issue
Hi everyone , can sb help me w/ it ?..
Kind regards :) ty in advance <3
I think this could get you a bit closer:
It's displaying like this :
I tried to change your code back and forth , but idk .. thx anyways.
how about this, then :
you probably forgot to put category smw , look :
can't check the code, when I don't have your solution setup ;)
Something like that?
so far so good
how about to wrap "view all" item ( item without category ) in a separate row , so it should be wrapped in a
something like...
okay , smth wrong with key , take a look :
but i just deleted this line ahhahah to see how it will be without category names
dope af , if we can fix repeating item "view all" and rendering categories
well, I think you should be able to get it working with the bits I've given.
I can't see why you get the "View all" two times -- it's only in the list once.
it's because i actually have a page in my content named "view all"
but even when i deleted it
cuz the row div isn't close afted view all rendered
final result , if let's go ultra last one w/ rendering it in a separe row
Other than that :
Couldn't have done it without you, understood the idea, goddamn code don't wanna work though.
is you casing correct? Item <> item
ohh, i know it, i just changed item to Item, cuz i already using name item in my code
anyways, it's throwing an error
