  • Robert Ghafoor 33 posts 95 karma points
    Aug 17, 2021 @ 13:37
    Robert Ghafoor
    How to set OwinContext.Environment for a custom middleware
    Im trying to implament saml ldp backoffice logins and im using "Sustainsys.Saml2.Owin" as a owin middleware this package require that you set the "saml2.idp" key: https://saml2.sustainsys.com/en/stable/owin-middleware.html
    I can however not figure out how to do this in Umbraco there is no way to get the actual OwinContext and set the key value even if i use GetOwinContext it throws "No envioment is found..." error.
    this is what i have so far to configure it using the open source test connector https://gist.github.com/robgha01/4409f5b0910c0b91d2360e64fd769fd1
    Aug 17, 2021 @ 20:04
    Robert Ghafoor
    Found a way to set it now BackOfficeExternalLoginProviderOptions.OnChallenge this function can return null if you want to stick with the default properties and its possible to do context.Set("saml2.idp", new EntityId("xxx")); now i just have to figure out the rest.
