Umbraco 7.4.3 - Images in Media not holding their preview
When loading images into Media section for use, the CMS is allowing the upload, recognising the a file has been loaded but doesn't retain the preview. When selecting the image to use in a blog page, it shows in the media selector, with no preview and when selected either doesnt show or displays an empty box.
I can rectify this by selecting 'remove files' and choosing the file again. The preview will then show for a few mins and then disappear again.
A possible issue
There is an image max upload size that may be set to a small number this may be the reason big images won't show up in the back office
if you check the security.config you will see this value Key is "MaxBytes"
I am having the same issue, very frustrating
Hi Carolyne
Check the log, please, looks like image resizing doesn't work properly
Alex
Hi Carolyne
A possible issue There is an image max upload size that may be set to a small number this may be the reason big images won't show up in the back office
Thanks Brandon
