  • Biagio Paruolo 1621 posts 1914 karma points c-trib
    Sep 20, 2021 @ 12:14
    Biagio Paruolo
    Sensiteve Data: How to manage?
    I wish to use Umbraco 8 or the upcoming v9 as headless data container. Some data are sensitive then I've to "crypto" them before saving and decrypt when reading. From Umbraco manager I'll create the document type and then from the content section I wish to see the data but cannot "edit" the sensitive data because encrypted ( field must be in read only mode ) else they are destroyed. How to?
  • Owain Jones 65 posts 437 karma points MVP 5x c-trib
    Sep 24, 2021 @ 15:04
    Owain Jones
    Would a label data type work for you here? https://our.umbraco.com/Documentation/Fundamentals/Backoffice/property-editors/built-in-property-editors/Label
    I've used them in the past whenever I needed to store/display a read-only value.
    Sep 24, 2021 @ 15:24
    Biagio Paruolo
    Thanks. I had forgotten that control. Have you some suggestion about headless to retrieve the content?
    Sep 27, 2021 @ 14:55
    Owain Jones
    Unfortunately, I've never used Umbraco Headless/Heartcore before so I don't know any specifics for that version of Umbraco.
    But, in standard v8, label properties are simply treated like normal properties (apart from being read-only in the backoffice) and you can retrieve their values as you would with any other property.
    Screenshot showing the code for retrieving the value of a property
    The Label property in the back office:
    Screenshot showing the label property editor in the backoffice
    Given that's how it behaves in v8, I would assume Umbraco Heartcore would also return it as a normal property value.
