I have the parameter configured in the macro as "CatID". However, when I drop the macro on a page, and provide a value for the parameter, it always displays as blank.
Hmm it seems like the you may want to try "catID" (no leading capitalization) for your parameter name.
Model.GetParameterValue<string>("catID");
It expects the macro parameter alias, which by default I believe get camel-cased when the macro is created, so unless you went and explicitly changed it to use "CatID" I bet it will work with "catID"
Partial View Macro Parameter Issue
I am trying to retrieve the macro parameter for a partial view.
The casing probably helped. But really it had to do with the way I was calling the parameter.
This didn't work:
But this did:
