composition.Sections().Append<MyFavouriteThingsSection>();
I add some custom code such as creating a file under a directory. I have hardcoded the path for testing i.e. c:\Umbraco\Files\myFile.txt
ICustomClass myClass = new MyClass();
myClass.CreateFile();
When the create file method hits it throws an error (System.Exception: Illegal characters in path) but using the same code outside of this method works successfully.
Is it possible to take a custom action here or is there another way to achieve this? Ideally i would like to take some actions when a new section is created.
Composers run on startup, so essentially you want to create your file when the site starts/reboots?
Don't think you can do it from within the section composer, but essentially you are not really doing anything that needs the section, you could create another component to run your code in:
Composer:
composition.Components().Append<MyFileCreationComponent>();
Component:
using Umbraco.Core.Composing;
namespace Testing.Composers
public class MyFileCreationComponent : IComponent
public void Initialize()
// Runs when the site starts up
public void Terminate()
// runs when the site shuts down, maybe some cleanup here?
That being said - I don't really know your usecase, but you probably don't need to create your file when you create the section - rather it should be created whenever some action that needs it is triggered?
Running tasks within IUserComposer Compose method
Im using this guide to build a section
https://our.umbraco.com/Documentation/Extending/Section-Trees/sections-v8
Within this method
Composer:
Component:
