I have a custom created section using the starter guide (https://our.umbraco.com/Documentation/Extending/Section-Trees/trees-v8) also utilising AngularJS.
Is there a way to display a page with records and edit the record on the same page? Ive seen this been done where you click a record field and it goes into edit mode but not sure if this is possible or if i need to create another page with the edit functionality?
I'm not sure what I'm looking for with the editor Service? I googled around and it seemed to be it was to do with creating a document type but as I say this is for a custom page locked down to only backend users.
I assume I would create another .html page, loading the record in the appropriate controls and allowing the user to edit the record?
If yes, do I just need to override the method where I add the favourite items (as per the example I posted above) and give a new page link?
Or anyone else? Just want to have confirmation of the correct way to have a edit page for any section pages i currently have?
At present i believe its adding in the additional parameter but as i say, would be great to get confirmation, this is the correct way of going about this?
foreach (var thing in favouriteThings)
// add each node to the tree collection using the base CreateTreeNode method
// it has several overloads, using here unique Id of tree item, -1 is the Id of the parent node to create, eg the root of this tree is -1 by convention - the querystring collection passed into this route - the name of the tree node - css class of icon to display for the node - and whether the item has child nodes
var node = CreateTreeNode(thing.Key.ToString(), "-1", queryStrings,
thing.Value,
"icon-presentation",
false,
"ADD PATH HERE USING TREE ALIAS AND ROUTE IT T0
APP_PLUGINS/MY_SECTION....");
nodes.Add(node);
So if i add a path by passing in the additional parameter to a location to my section currently residing in app_plugins/mysection/backoffice etc i can add a standard HTML page call it editMyPage.html and use this area to edit the record?
If so i dont want it to list the title of the editMyPage.html on the left menu as it should only be displayed/accessible when a record is clicked on the list of records page itself i.e.
Record 1 Edit
Record 2 Edit
Record 3 Edit
Record 4 Edit
So assuming the above is a list page when the user clicks Edit they would be taken to a new edit page but the edit page is not listed on the left menu.
Alternatively if this is not possible then would it be configuring the Edit link to a page through Angular on the lists page?
Possible to edit a row on same page in custom section?
There is nothing in umbraco that can handle this, since the table view is mostly used to display only a few details, to help you identity a record.
Editing could be done via an overlay that can be opened when click the record. Look into the editorService for examples of this.
HTH :-)
Hi Søren Gregersen
Record 1 Edit
Record 2 Edit
Record 3 Edit
Record 4 Edit
