I was just wondering is it possible to have a uSync automatically pick up new changes to content and import?
E.g I have a system which generates an XML file which puts it in the uSync folder then the website reports and imports?
Hi Matt,
you could use the uSync.Triggers package - to trigger an import from the command line after the files are created, or you could lift some of the code out of the Trigger controller and roll your own update methods.
https://github.com/KevinJump/uSyncTriggers/blob/main/uSync.Triggers/Controllers/TriggerController.cs
Upload image
uSync automation
Hi Matt,
