  • deleted user 20 posts 110 karma points
    Dec 22, 2021 @ 15:53
    deleted user
    Login taking ages and fails at first attempt + a lot KeepAlive errors
    Suddenly on all environments (dev + prod) the Login is taking ages at first try and then fails with error "Login failed for user xxxx"
    Then, on the second try login is working.
    But I'm not able to access the "Users" section. The section is loading to death with no error.
    When checking the Logs I had tons of "Keep alive failed" errors popping in every 5 min. So I changed the keep alive URL to localhost. Now the errors are gone but I'm still not able to log in at once.
    It's a load balanced infra and the Version of Umbraco is 8.6.1.
