  • Kareem 5 posts 76 karma points
    Dec 23, 2021 @ 08:26
    Kareem
    uSync 8.10.6 issue
    I am using umbraco version 8.13 and uSync version 8.10.6 and there is an issue while applying the importing of data types & doc types were the new changes are not imported however the UI, logs, browser console do not reveal any issues even after enabling the uSync logging and the result is always success but nothing is actually imported.
    Regards, Kareem
  • Kevin Jump 2348 posts 14896 karma points MVP 8x c-trib
    Dec 23, 2021 @ 11:01
    Kevin Jump
    Hi Kareem,
    if you run a report before an import does the uSync UI say there are any changes to be imported ?
    when you run an import with the logging on, can you see the items / properties being processed in the logs ?
    Kevin
    Dec 23, 2021 @ 11:49
    Kareem
    Hi Kevin,
    Yes, the report shows that there are changes.
    For the logs, I can see only "ReportFolder: " along with the folder path and the count of files repeated for all of the features.
    This is the report snapshot
    This is the import result snapshot
    Kareem
