  • Jon Frederiksen 52 posts 111 karma points
    Jan 03, 2022 @ 09:33
    Jon Frederiksen
    Upgrade 7 to 8: Input string was not in a correct format
    I hope someone can help me with a hint on where to look and what to look after.
    I'm upgrading an Umbraco 7.17.5 to Umbraco 8.1.6 and everything seems ok, except this fatal error:
    The database failed to upgrade. ERROR: The database configuration failed with the following message: Input string was not in a correct format. Please check log file for additional information (can be found in '/App_Data/Logs/')
    The log file dosen't show more info (what, where), so I'm totally blank.
    Bellow, the entries regarding the error:
    {"@t":"2022-01-03T08:40:06.1714812Z","@mt":"Installation step {Step} failed.","@l":"Error","@x":"System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> Umbraco.Web.Install.InstallException: The database failed to upgrade. ERROR: The database configuration failed with the following message: Input string was not in a correct format.\n Please check log file for additional information (can be found in '/App_Data/Logs/')\r\n   at Umbraco.Web.Install.InstallSteps.DatabaseUpgradeStep.ExecuteAsync(Object model)\r\n   --- End of inner exception stack trace ---\r\n   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)\r\n   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)\r\n   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)\r\n   at Umbraco.Web.Install.Controllers.InstallApiController.<ExecuteStepAsync>d__14.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at Umbraco.Web.Install.Controllers.InstallApiController.<PostPerformInstall>d__11.MoveNext()","Step":"DatabaseUpgrade","SourceContext":"Umbraco.Web.Install.Controllers.InstallApiController","ProcessId":5884,"ProcessName":"w3wp","ThreadId":172,"AppDomainId":3,"AppDomainAppId":"LMW3SVC4ROOT","MachineName":"WIN10","Log4NetLevel":"ERROR","HttpRequestNumber":11,"HttpRequestId":"01322042-a023-4bbf-9a24-4342fded4c33"}
    {"@t":"2022-01-03T08:40:06.1714812Z","@mt":"{EndMessage} ({Duration}ms) [Timing {TimingId}]","EndMessage":"Step completed","Duration":2082588,"TimingId":"3f3f049","SourceContext":"Umbraco.Web.Install.Controllers.InstallApiController","ProcessId":5884,"ProcessName":"w3wp","ThreadId":172,"AppDomainId":3,"AppDomainAppId":"LMW3SVC4ROOT","MachineName":"WIN10","Log4NetLevel":"INFO ","HttpRequestNumber":11,"HttpRequestId":"01322042-a023-4bbf-9a24-4342fded4c33"}
    {"@t":"2022-01-03T08:40:06.1714812Z","@mt":"An error occurred during installation step {Step}","@l":"Error","@x":"System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> Umbraco.Web.Install.InstallException: The database failed to upgrade. ERROR: The database configuration failed with the following message: Input string was not in a correct format.\n Please check log file for additional information (can be found in '/App_Data/Logs/')\r\n   at Umbraco.Web.Install.InstallSteps.DatabaseUpgradeStep.ExecuteAsync(Object model)\r\n   --- End of inner exception stack trace ---\r\n   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)\r\n   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)\r\n   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)\r\n   at Umbraco.Web.Install.Controllers.InstallApiController.<ExecuteStepAsync>d__14.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)\r\n   at Umbraco.Web.Install.Controllers.InstallApiController.<PostPerformInstall>d__11.MoveNext()","Step":"DatabaseUpgrade","SourceContext":"Umbraco.Web.Install.Controllers.InstallApiController","ProcessId":5884,"ProcessName":"w3wp","ThreadId":172,"AppDomainId":3,"AppDomainAppId":"LMW3SVC4ROOT","MachineName":"WIN10","Log4NetLevel":"ERROR","HttpRequestNumber":11,"HttpRequestId":"01322042-a023-4bbf-9a24-4342fded4c33"}
    Any help much appreciated. Thanks
  • Ayo Adesina 445 posts 1059 karma points
    Jan 04, 2022 @ 00:11
    Ayo Adesina
    Hi Jon, From what I understand you can really upgrade from 7-8 in the normal way you would upgrade umbraco.
    What you need to do is migrate the content in to a new installation of Umbraco 8.
    Have a look at this article here:
    https://our.umbraco.com/Documentation/Fundamentals/Setup/Upgrading/migrating-to-v8
