  • Debasish Gracias 32 posts 164 karma points
    Jan 12, 2022 @ 17:12
    Debasish Gracias
    Issue with Umbraco Forms with anti forgery token and Azure front door caching enabled
    I just ran across an issue I hadn't experienced before, and wanted to see if there was a solution for it.
    We have umbraco site version 7.15.3 running on Azure. We are using umbraco forms V 7.0.7 and has the anti forgery token enabled in UmbracoForms.config. We also have enabled default caching on front door (output caching). With this setup, when a form is submitted we get the below error
    System.Web.Mvc.HttpAntiForgeryException (0x80004005): The required anti-forgery cookie "__RequestVerificationToken" is not present.
    at System.Web.Helpers.AntiXsrf.TokenValidator.ValidateTokens(HttpContextBase httpContext, IIdentity identity, AntiForgeryToken sessionToken, AntiForgeryToken fieldToken)
    at System.Web.Helpers.AntiXsrf.AntiForgeryWorker.Validate(HttpContextBase httpContext)
    at System.Web.Helpers.AntiForgery.Validate()
    at Umbraco.Forms.Core.Common.ValidateFormsAntiForgeryTokenAttribute.OnAuthorization(AuthorizationContext filterContext)
    Things we have tried
    1. Disabling caching on front door and enabling anti forgery token works i.e the umbraco forms are successfully submitted
    2. Enabling caching on front door and disabling the anti forgery token works i.e the umbraco forms are successfully submitted
    Questions:
    1. Is there a way to get it to work with caching enabled on front door and with anti forgery token enabled? H
    2. Has this been addressed with the latest version of umbraco forms and umbraco cms?
  • Bobi 352 posts 966 karma points
    Apr 26, 2022 @ 04:12
    Bobi
    Did you ever figure this out?
