  • Bram van den Bogaard 9 posts 104 karma points
    Feb 02, 2022 @ 18:16
    Archetype settings marked as required can still be left empty
    Hi all,
    I'm working on an Umbraco 7 project that uses Archetypes. During testing I've noticed that fields that are marked as "required" can just be left empty and the node can still be saved. I've noticed that this is the case for all my Archetypes.
    Does anyone have a fix for this issue?
  • Chris Kim 48 posts 254 karma points c-trib
    Feb 02, 2022 @ 23:10
    Chris Kim
    What version of Archetype is your project using? There is a related issue that was supposed to be fixed in version 1.14.1:
    https://github.com/kgiszewski/Archetype/issues/395
    Feb 03, 2022 @ 08:41
    Hi Chris, Thanks for the reply.
    I'm currently using version 1.15.1. I updated to 1.18.0 but unfortunately the issue still remains.
