  • daniel snyder 7 posts 97 karma points
    Feb 03, 2022 @ 05:24
    daniel snyder
    Github and Umbraco-CMS
    I downloaded the Umbraco-CMS code base from github and it did not compile. and gave this error.
    Severity Code Description Project File Line Suppression State Error MSB3073 The command "npm ci" exited with code 9009. Umbraco.Web.UI C:\Users\Downloads\Umbraco-CMS-9-contrib (1)\Umbraco-CMS-9-contrib\src\Umbraco.Web.UI\Umbraco.Web.UI.csproj 110
    I removed these lines from the project file which allowed it to build,
    Target Name="BelleBuild" Exec WorkingDirectory="$(ProjectDir)/../Umbraco.Web.UI.Client/" Command="npm ci" Exec WorkingDirectory="$(ProjectDir)/../Umbraco.Web.UI.Client/" Command="npm run build:skip-tests" Target
    CallTarget Targets="BelleBuild" Condition="!Exists('$(BellePath)') and '$(UmbracoBuild)' == ''"
    Then it compiles but won't run, and gives this error.
    A server error occurred This is most likely due to an error during application startup
    Did you know {{installer.feedback}}
    //END OF ERROR Copy
    Any suggestions on how to get the Umbraco code to run? What am I missing?
    Thanks!
  • Søren Kottal 713 posts 4571 karma points MVP 6x c-trib
    Feb 03, 2022 @ 09:08
    Søren Kottal
    Hi Daniel
    Sounds like you don't have node installed
    Try following the guide at https://github.com/umbraco/Umbraco-CMS/blob/v9/contrib/.github/CONTRIBUTING.md#working-with-the-code
    Feb 06, 2022 @ 01:18
    daniel snyder
    Thank you, I will try this out.
  • daniel 4 posts 24 karma points
    Feb 06, 2022 @ 03:46
    daniel
    I just saw this, and since I don't know much (anything) about npm, I have to ask, is this a danger?
    https://threatpost.com/malicious-npm-packages-web-apps/178137/
