  • Ross Ballantine 3 posts 74 karma points
    Feb 17, 2022 @ 13:43
    Ross Ballantine
    Excluding node value from Examine index
    Hi, Is there any way in Umbrac v9 to exclude certain content values from the examine index? In this instance I have a multi-node treepicker used to highlight related content which I want to exclude from search indexing and showing up in the search results. Currently I have overridden the 'PerformingIndexValues' event to do this, but I can only see an option to add or combing values, instead of removing them from the Index (see code below).
    private void IndexProviderTransformingIndexValues(object sender, IndexingItemEventArgs args)
            try
                if (int.TryParse(args.ValueSet.Id, out var pageId))
                    if (args.ValueSet.ItemType == "newsArticle") //Set news article custom index fields
                        using (UmbracoContextReference umbracoContextReference = _umbracoContextFactory.EnsureUmbracoContext())
                            var contentNode = umbracoContextReference.UmbracoContext.Content.GetById(pageId);
                            if (contentNode != null)
                                args = SetSearchableValues(args, contentNode);
            catch (Exception e)
                _logger.LogError(e, "IndexProviderTransformingIndexValues: Exception: {0} | Message: {1} | Stack Trace: {2}", e.InnerException != null ? e.InnerException.ToString() : "", e.Message != null ? e.Message.ToString() : "", e.StackTrace);
        private IndexingItemEventArgs SetSearchableValues(IndexingItemEventArgs args, IPublishedContent contentNode)
            try
                var combinedFields = new StringBuilder();
                //Loop through all fields and combine into single string of searchable content
                foreach (var fieldValues in args.ValueSet.Values)
                    foreach (var value in fieldValues.Value)
                        if (value != null)
                            combinedFields.AppendLine(value.ToString());
                //Index custom field values
                args.ValueSet.Add("searchHomepageKey", contentNode.AncestorOrSelf("homePage").Key.ToString());
                args.ValueSet.Add("searchParentKey", contentNode.Parent.Key.ToString());
                args.ValueSet.Set("searchCurrentKey", contentNode.Key.ToString());
                args.ValueSet.Add("searchableKeywords", combinedFields.ToString().ToLower());
                args.ValueSet.Set("sortableDate", contentNode.CreateDate.ToString("yyyyMMddHHmmss"));
            catch (Exception e)
                _logger.LogError(e, "SetSearchableValues: Exception: {0} | Message: {1} | Stack Trace: {2}", e.InnerException != null ? e.InnerException.ToString() : "", e.Message != null ? e.Message.ToString() : "", e.StackTrace);
            return args;
    Any help much appreciated.
