As it turns out, there were orphaned records in the db that seem to have been the cause. My fix was to write a SQL Script that migrates the data from a U8 database to a Clean U9. I am including it below for anyone else that may benefit.
I am still in the process of migrating the site. My problem is I am getting this error on the back end when I click on a page in the Content Tree:
Request error: The URL returned a 404 (not found):
/umbraco/backoffice/umbracoapi/content/GetById
Any Ideas?
Thanks!
SQL SERVER MIGRATION SCRIPT
-- Author: Graham Davis
-- Company: zBestData.com
-- Created: 02/18/2022
-- Updated: 02/18/2022 - Initial Script
-- Description: Convert Umbraco 8 Database to Umbraco 9
-- using a clean U9 MDF
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoNode] ON;
INSERT INTO[Umbraco9].[dbo].[umbracoNode] ([id]
,[uniqueId]
,[parentId]
,[level]
,[path]
,[sortOrder]
,[trashed]
,[nodeUser]
,[text]
,[nodeObjectType]
,[createDate])
SELECT * FROM [Umbraco8].[dbo].[umbracoNode]
WHERE id NOT IN (SELECT id FROM [Umbraco9].[dbo].[umbracoNode]);
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoNode] OFF;
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsContentType] ON;
INSERT INTO[Umbraco9].[dbo].[cmsContentType] ([pk]
,[nodeId]
,[alias]
,[icon]
,[thumbnail]
,[description]
,[isContainer]
,[isElement]
,[allowAtRoot]
,[variations])
SELECT * FROM [Umbraco8].[dbo].[cmsContentType]
WHERE pk NOT IN (SELECT pk FROM [Umbraco9].[dbo].[cmsContentType])
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsContentType] OFF;
INSERT INTO[Umbraco9].[dbo].[umbracoContent]( [nodeId]
,[contentTypeId])
SELECT * FROM [Umbraco8].[dbo].[umbracoContent]
WHERE contentTypeId IN (SELECT nodeId FROM [Umbraco9].[dbo].[cmsContentType]);
INSERT INTO[Umbraco9].[dbo].[cmsContentNu] ([nodeId]
,[published]
,[data]
,[rv])
SELECT * FROM [Umbraco8].[dbo].[cmsContentNu]
WHERE nodeId IN (SELECT nodeId FROM [Umbraco9].[dbo].[umbracoContent]);
INSERT INTO[Umbraco9].[dbo].[cmsContentType2ContentType] ([parentContentTypeId]
,[childContentTypeId])
SELECT * FROM [Umbraco8].[dbo].[cmsContentType2ContentType];
WHERE parentContentTypeId NOT IN (SELECT parentContentTypeId FROM [Umbraco9].[dbo].[cmsContentType2ContentType]);
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsTemplate] ON;
INSERT INTO[Umbraco9].[dbo].[cmsTemplate]([pk]
,[nodeId]
,[alias])
SELECT * FROM [Umbraco8].[dbo].[cmsTemplate]
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsTemplate] OFF;
INSERT INTO[Umbraco9].[dbo].[cmsDocumentType] ([contentTypeNodeId]
,[templateNodeId]
,[IsDefault])
SELECT * FROM [Umbraco8].[dbo].[cmsDocumentType]
WHERE [contentTypeNodeId] IN (
SELECT nodeId FROM [Umbraco9].[dbo].cmsContentType)
INSERT INTO[Umbraco9].[dbo].[umbracoDocument] ( [nodeId]
,[published]
,[edited])
SELECT * FROM [Umbraco8].[dbo].[umbracoDocument]
WHERE nodeId IN ( SELECT nodeId FROM [Umbraco9].[dbo].[umbracoContent])
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoContentVersion] ON;
INSERT INTO[Umbraco9].[dbo].[umbracoContentVersion] ([id]
,[nodeId]
,[versionDate]
,[userId]
,[current]
,[text])
--,[preventCleanup])
SELECT [id]
,[nodeId]
,[versionDate]
,[userId]
,[current]
,[text]
FROM [Umbraco8].[dbo].[umbracoContentVersion] WHERE [current] = 1
AND nodeId IN ( SELECT nodeId FROM [Umbraco9].[dbo].[umbracoContent])
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoContentVersion] OFF;
INSERT INTO[Umbraco9].[dbo].[umbracoContentSchedule]( [id]
,[nodeId]
,[languageId]
,[date]
,[action])
SELECT * FROM [Umbraco8].[dbo].[umbracoContentSchedule];
INSERT INTO[Umbraco9].[dbo].[umbracoDataType] ([nodeId]
,[propertyEditorAlias]
,[dbType]
,[config])
SELECT * FROM [Umbraco8].[dbo].[umbracoDataType]
WHERE nodeId NOT IN (SELECT nodeId FROM [Umbraco9].[dbo].[umbracoDataType]);
INSERT INTO[Umbraco9].[dbo].[umbracoDocumentVersion] ([id]
,[templateId]
,[published])
SELECT * FROM [Umbraco8].[dbo].[umbracoDocumentVersion] WHERE published = 1
AND id IN (SELECT id FROM [umbracoContentVersion]);
INSERT INTO[Umbraco9].[dbo].[umbracoMediaVersion] ([id]
,[paath])
SELECT * FROM [Umbraco8].[dbo].[umbracoMediaVersion]
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsPropertyTypeGroup] ON;
INSERT INTO[Umbraco9].[dbo].[cmsPropertyTypeGroup] (id
,[uniqueID]
,[contenttypeNodeId]
--,[type]
,[text]
,[alias]
,[sortorder])
SELECT id
,[uniqueID]
--,[type]
,[text]
,[text] AS [alias]
,[sortorder]
FROM [Umbraco8].[dbo].[cmsPropertyTypeGroup]
WHERE id NOT IN (SELECT id FROM [Umbraco9].[dbo].[cmsPropertyTypeGroup]);
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsPropertyTypeGroup] OFF;
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsPropertyType] ON;
INSERT INTO[Umbraco9].[dbo].[cmsPropertyType] ([id]
,[dataTypeId]
,[contentTypeId]
,[propertyTypeGroupId]
,[Alias]
,[Name]
,[sortOrder]
,[mandatory]
,[mandatoryMessage]
,[validationRegExp]
,[validationRegExpMessage]
,[Description]
,[labelOnTop]
,[variations]
,[UniqueID])
SELECT * FROM [Umbraco8].[dbo].[cmsPropertyType]
WHERE id NOT IN (SELECT id FROM [Umbraco9].[dbo].[cmsPropertyType]);
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsPropertyType] OFF;
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoPropertyData] ON;
INSERT INTO[Umbraco9].[dbo].[umbracoPropertyData]([id]
,[versionId]
,[propertyTypeId]
,[languageId]
,[segment]
,[intValue]
,[decimalValue]
,[dateValue]
,[varcharValue]
,[textValue])
SELECT * FROM [Umbraco8].[dbo].[umbracoPropertyData]
WHERE versionId IN (SELECT ID FROM [Umbraco9].[dbo].[umbracoContentVersion]);
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoPropertyData] OFF;
INSERT INTO[Umbraco9].[dbo].[umbracoRedirectUrl]([id]
,[contentKey]
,[createDateUtc]
,[url]
,[culture]
,[urlHash])
SELECT * FROM [Umbraco8].[dbo].[umbracoRedirectUrl];
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoRelation] ON;
INSERT INTO[Umbraco9].[dbo].[umbracoRelation] ([id]
,[parentId]
,[childId]
,[relType]
,[datetime]
,[comment])
SELECT * FROM [Umbraco8].[dbo].[umbracoRelation];
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoRelation] OFF;
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoUser] ON;
INSERT INTO[Umbraco9].[dbo].[umbracoUser] ([id]
,[userDisabled]
,[userNoConsole]
,[userName]
,[userLogin]
,[userPassword]
,[passwordConfig]
,[userEmail]
,[userLanguage]
,[securityStampToken]
,[failedLoginAttempts]
,[lastLockoutDate]
,[lastPasswordChangeDate]
,[lastLoginDate]
,[emailConfirmedDate]
,[invitedDate]
,[createDate]
,[updateDate]
,[avatar]
,[tourData])
SELECT * FROM [Umbraco8].[dbo].[umbracoUser]
WHERE id NOT IN (SELECT id FROM [Umbraco9].[dbo].[umbracoUser]);
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoUser] OFF;
INSERT INTO[Umbraco9].[dbo].[umbracoUser2UserGroup] ([userId]
,[userGroupId])
SELECT * FROM [Umbraco8].[dbo].[umbracoUser2UserGroup]
WHERE userId NOT IN (SELECT userId FROM [Umbraco9].[dbo].[umbracoUser2UserGroup]);
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoUserGroup] ON;
INSERT INTO[Umbraco9].[dbo].[umbracoUserGroup] ([id]
,[userGroupAlias]
,[userGroupName]
,[userGroupDefaultPermissions]
,[createDate]
,[updateDate]
,[icon]
,[startContentId]
,[startMediaId])
SELECT * FROM [Umbraco8].[dbo].[umbracoUserGroup]
WHERE ID NOT IN (SELECT id FROM [Umbraco9].[dbo].[umbracoUserGroup]);
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoUserGroup] OFF;
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoUserStartNode] ON;
INSERT INTO[Umbraco9].[dbo].[umbracoUserStartNode] ([id]
,[userId]
,[startNode]
,[startNodeType])
SELECT * FROM [Umbraco8].[dbo].[umbracoUserStartNode];
SET IDENTITY_INSERT [Umbraco9].[dbo].[umbracoUserStartNode] OFF;
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsMacro] ON;
INSERT INTO[Umbraco9].[dbo].[cmsMacro] ([id]
,[uniqueId]
,[macroUseInEditor]
,[macroRefreshRate]
,[macroAlias]
,[macroName]
,[macroCacheByPage]
,[macroCachePersonalized]
,[macroDontRender]
,[macroSource]
,[macroType])
SELECT * FROM [Umbraco8].[dbo].[cmsMacro];
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsMacro] OFF;
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsMacroProperty] ON;
INSERT INTO[Umbraco9].[dbo].[cmsMacroProperty] ([id]
,[uniquePropertyId]
,[editorAlias]
,[macro]
,[macroPropertySortOrder]
,[macroPropertyAlias]
,[macroPropertyName])
SELECT * FROM [Umbraco8].[dbo].[cmsMacroProperty];
SET IDENTITY_INSERT [Umbraco9].[dbo].[cmsMacroProperty] OFF;
The URL returned a 404 (not found): /umbraco/backoffice/umbracoapi/content/GetById-
I have been having difficulty migrating a U8 Site to U9 and originally posted about it on the Umbraco Facebook group(link below)
https://www.facebook.com/photo?fbid=10227095786723405&set=gm.1479985932403293
Any Ideas?
Thanks!
