I tried to add google login verification to the umbraco backoffice login page,
but the problem of redirection failed.
After I clicked to log in with a google account, an error message from google appeared on the page, error 400. After checking for a long time, I really I don't know what I did wrong, so I came up and asked, I hope you can help, thank you.
The following are the parameters and programs I set. I wrote two programs, GoogleBackofficeAuthenticationExtensions.cs and GoogleBackOfficeExternalLoginProviderOptions.cs.
using Umbraco.Cms.Core.DependencyInjection;
using Umbraco.Extensions;
using Umbraco.Cms.Web.BackOffice.Security;
using Microsoft.Extensions.DependencyInjection;
using Microsoft.Extensions.Configuration;
namespace UmbracoDemo1.OAuth
public static class GoogleBackofficeAuthenticationExtensions
public static IUmbracoBuilder AddGoogleBackofficeAuthentication(this IUmbracoBuilder builder)
builder.AddBackOfficeExternalLogins(logins =>
logins.AddBackOfficeLogin(
backOfficeAuthenticationBuilder =>
backOfficeAuthenticationBuilder.AddGoogle(
// The scheme must be set with this method to work for the back office
backOfficeAuthenticationBuilder.SchemeForBackOffice(GoogleBackOfficeExternalLoginProviderOptions.SchemeName),
options =>
////只有 OAuth 同意畫面中列出的測試使用者具備 OAuth 存取權限,名單如下:
////wunhueic@gmail.com
//// By default this is '/signin-google' but it needs to be changed to this
IConfigurationSection googleAuthNSection = builder.Config.GetSection("Authentication:Google");
options.CallbackPath = googleAuthNSection["CallbackPath"];
options.ClientId = googleAuthNSection["ClientId"];
options.ClientSecret = googleAuthNSection["ClientSecret"];
return builder;
//builder.AddBackOfficeExternalLogins(loginOptions =>
// loginOptions.AddBackOfficeLogin(new BackOfficeExternalLoginProviderOptions(
// "btn-success",
// "fa-google"
// ), authOptions => authOptions.AddGoogle("Umbraco.Google","Google", options =>
// IConfigurationSection googleAuthNSection = builder.Config.GetSection("Authentication:Google");
// options.ClientId = googleAuthNSection["ClientId"];
// options.ClientSecret = googleAuthNSection["ClientSecret"];
//return builder;
using Microsoft.Extensions.Options;
using Umbraco.Cms.Core;
public class GoogleBackOfficeExternalLoginProviderOptions : IConfigureNamedOptions<BackOfficeExternalLoginProviderOptions>
public const string SchemeName = "Google";
public void Configure(string name, BackOfficeExternalLoginProviderOptions options)
if (name != "Umbraco." + SchemeName)
return;
Configure(options);
public void Configure(BackOfficeExternalLoginProviderOptions options)
options.ButtonStyle = "btn-danger";
options.Icon = "fa fa-cloud";
options.AutoLinkOptions = new ExternalSignInAutoLinkOptions(
// must be true for auto-linking to be enabled
autoLinkExternalAccount: true,
// Optionally specify default user group, else
// assign in the OnAutoLinking callback
// (default is editor)
defaultUserGroups: new[] { Constants.Security.EditorGroupAlias },
// Optionally specify the default culture to create
// the user as. If null it will use the default
// culture defined in the web.config, or it can
// be dynamically assigned in the OnAutoLinking
// callback.
defaultCulture: null,
// Optionally you can disable the ability to link/unlink
// manually from within the back office. Set this to false
// if you don't want the user to unlink from this external
// provider.
allowManualLinking: false
// Optional callback
OnAutoLinking = (autoLinkUser, loginInfo) =>
// You can customize the user before it's linked.
// i.e. Modify the user's groups based on the Claims returned
// in the externalLogin info
OnExternalLogin = (user, loginInfo) =>
// You can customize the user before it's saved whenever they have
// logged in with the external provider.
// i.e. Sync the user's name based on the Claims returned
return true; //returns a boolean indicating if sign in should continue or not.
// Optionally you can disable the ability for users
// to login with a username/password. If this is set
// to true, it will disable username/password login
// even if there are other external login providers installed.
options.DenyLocalLogin = false;
// Optionally choose to automatically redirect to the
// external login provider so the user doesn't have
// to click the login button. This is
options.AutoRedirectLoginToExternalProvider = false;
I am also facing the same issue. I want to create google login page for website not for Umbraco administrator. If your issue is resolved, please help me as well.
Umbraco 9 google oauth problem
I tried to add google login verification to the umbraco backoffice login page, but the problem of redirection failed.
Hello tuobaling,
