I'm looking for guidance on how to change the Razor view location order in an Umbraco 9.3 solution.
My goal is to have the web application prioritise .cshtml view files located in the ~/Foo/ directory. So far, I've only been able to add this folder to the end of the view location order.
Startup.cs
using Microsoft.AspNetCore.Builder;
using Microsoft.AspNetCore.Hosting;
using Microsoft.AspNetCore.Mvc.Razor;
using Microsoft.Extensions.Configuration;
using Microsoft.Extensions.DependencyInjection;
using Microsoft.Extensions.Hosting;
using Umbraco.Cms.Core.DependencyInjection;
using Umbraco.Extensions;
namespace Umbraco.Templates.Site
public class Startup
private readonly IWebHostEnvironment _env;
private readonly IConfiguration _config;
public Startup(IWebHostEnvironment webHostEnvironment, IConfiguration config)
_env = webHostEnvironment;
_config = config;
public void ConfigureServices(IServiceCollection services)
// Configure the custom view location order
services.ConfigureOptions<CustomRenderRazorViewEngineOptionsSetup>();
services.AddUmbraco(_env, _config)
.AddBackOffice()
.AddWebsite()
.AddComposers()
.Build();
public void Configure(IApplicationBuilder app, IWebHostEnvironment env)
if (env.IsDevelopment())
app.UseDeveloperExceptionPage();
app.UseUmbraco()
.WithMiddleware(u =>
u.UseBackOffice();
u.UseWebsite();
.WithEndpoints(u =>
u.UseInstallerEndpoints();
u.UseBackOfficeEndpoints();
u.UseWebsiteEndpoints();
CustomRenderRazorViewEngineOptionsSetup.cs
Based on Umbraco's own RenderRazorViewEngineOptionsSetup.cs
using System;
using System.Linq;
using Microsoft.Extensions.Options;
/// <summary>
/// Configure view engine locations for front-end rendering
/// </summary>
public class RenderRazorViewEngineOptionsSetup : IConfigureOptions<RazorViewEngineOptions>
/// <inheritdoc/>
public void Configure(RazorViewEngineOptions options)
if (options == null)
throw new ArgumentNullException(nameof(options));
options.ViewLocationExpanders.Add(new ViewLocationExpander());
/// <summary>
/// Expands the default view locations
/// </summary>
private class ViewLocationExpander : IViewLocationExpander
public IEnumerable<string> ExpandViewLocations(ViewLocationExpanderContext context, IEnumerable<string> viewLocations)
string[] umbViewLocations = new string[]
"/Foo/Views/{0}.cshtml",
"/Foo/Views/Shared/{0}.cshtml",
"/Foo/Views/Partials/{0}.cshtml",
"/Foo/Views/MacroPartials/{0}.cshtml",
viewLocations = umbViewLocations.Concat(viewLocations);
return viewLocations;
// not a dynamic expander
public void PopulateValues(ViewLocationExpanderContext context) { }
This results in the following view location order, with the default Umbraco view locations taking priority:
/App_Plugins/Views/
/App_Plugins/Views/Shared
/App_Plugins/Views/Partials/
/App_Plugins/Views/MacroPartials/
/Views/
/Views/Shared/
/Views/Partials/
/Foo/Views/
/Foo/Views/Shared/
How can I get the four ~/Foo/ items to the top of the list of view locations?
Change Razor View Location Order in Umbraco 9
.cshtmlview files located in the~/Foo/directory. So far, I've only been able to add this folder to the end of the view location order.Startup.cs
RenderRazorViewEngineOptionsSetup.csThis results in the following view location order, with the default Umbraco view locations taking priority:
~/Foo/items to the top of the list of view locations?Other things I've tried:
services.Configure()instead ofservices.ConfigureOptions().services.AddUmbraco() ... .Build();instead of before.Any idea as to how I could gain more control over the view location order?
I had this same problem. Check this github issue for a solution: https://github.com/umbraco/Umbraco-CMS/issues/12157
Essentially you'll want to override the default razor view engine replacing it with one which adds your custom view expanders before the umbraco ones.
This is exactly what I was looking for, thank you for sharing!
