Form does not keep the submitted data when validation fails
I have the following problem:
simple contact form. If I omit for example a required field, then the form displays errors, but the data that was filled does not appear.
I would greatly appreciate if someone can explain to me why the submitted that is not displayed back.
I would expect that CurrentUmbracoPage(); just resubmits the POST method. instead it redirects to the RenderForm. Is this normal? Given that flow, how could I even expect the submitted model given I have a line that creates new one:
ContactUsViewModel model = this.contactUsViewModelFactory.CreateContactUsViewModel();
I am missing something - either the flow should not be returning to the RenderForm or somehow the old data from the post should be passed to it.
I would expect that
CurrentUmbracoPage();just resubmits the POST method. instead it redirects to theRenderForm. Is this normal? Given that flow, how could I even expect the submitted model given I have a line that creates new one:I am missing something - either the flow should not be returning to the
RenderFormor somehow the old data from the post should be passed to it.Here is the code:
The viewmodel is pretty standard I believe:
The partial _ContactUsForm.cshtml:
And the view itself has just slightly been modified to use the recaptcha:
