As cannot find a suitable colour picker I'm trying to replicate the colour picker umbraco uses. It uses the spectrum library and its actually the colour picker the approved colour picker uses when defining the colours.
If there is an easier way please tell me. However i need to call the $().spectrum() method to initalise the input element however, when I call that from within the controller the element is not setup properly. If i call $().spectrum() in a script tag in the property editor html for example, it is initialised but the 'color' property which is equal to model.value, is not correctly set. If I output model.value I can see it has the correct value but it needs to be set within the js config element $().spectrum({'color':model.value}).
Calling a jquery method on an element of a property editor from an angular controller
using V9
Any advice is appreciated.
