  • ReneRam 21 posts 186 karma points
    Apr 06, 2022 @ 08:08
    ReneRam
    BeginUmbracoForm: validation for @Html.CheckBoxFor not returning Error Message
    Hi to everyone. I'm having difficult obtaining the ErrorMesage from my class in a Surface Controller Form. Everything works as expected except for the validation message when a required checkbox must be ticked. I've been trying many things, but the result is always the same: No Error Message.
    Following is part of my Model:
            [Required(ErrorMessage = "L'Oggetto della richiesta è un campo Obbligatorio")]
        [Display(Name = "Oggetto")]
        public string Oggetto { get; set; }
        [Required(ErrorMessage = "La Descrizione della richiesta è un campo Obbligatorio")]
        [Display(Name = "Descrizione")]
        public string Descrizione { get; set; }
        //[Required(ErrorMessage = "È necessario confermare di aver letto l'informativa sulla privacy.")]
        //[Range(typeof(bool), "false", "true", ErrorMessage = "È necessario confermare di aver letto")]    // funziona a rovescio
        [Range(typeof(bool), "true", "true", ErrorMessage = "È necessario confermare di aver letto l'informativa!")]
        [Display(Name = "Informativa sulla Privacy")]
        public bool Privacy { get; set; }
    As you can see I have tried also with the [Required] attribute.
    Following is the View fragment:
        @* Privacy *@
        <div class="row mb-3">
            <div class="col">
                @Html.CheckBoxFor(m => m.Privacy, new { @class = "form-check form-check-inline", @style = "width:25px; height:25px" })
                @Html.LabelFor(m => m.Privacy)<i>&ast;</i>
                @Html.ValidationMessageFor(m => m.Privacy, "", new { @class = "text-danger font-weight-bold blinkingText" })
        @* Submit *@
            <div class="col text-center">
                <input type="submit" value="Invia Richiesta" class="btn btn-cyan" />
    the view fragment is wrapped inside a using (Html.BeginUmbracoForm("Submit", "FormContatti"))
    When I submit with missing fields I get back to the view with all error messages displayed except for the checkbox that has to by ticked:
    Anyone can help? Thanks René
    Apr 09, 2022 @ 16:35
    ReneRam
    Found a solution in an old Stack Overflow post:
    MVC Model require true
    In case anyone has the same problem
