I have set post moderation for my form. How do I approve a entry programmatically? This will happen from a web hook.
+1 to this
Hi, I did figure this out. Forgot to update my question. See below!
First you need to get the Form from the IFormService.
Form
IFormService
var form = _formService.Get("formId");
Then you can use the IRecordStorage to get a Record by ID. You'll also need to parse the form.
IRecordStorage
Record
var record = _recordStorage.Get("recordId", form);
And using the IRecordService you can approve records.
IRecordService
_recordService.Approve(record, form);
UmbracoForms - Approve entry programmatically
+1 to this
Formfrom theIFormService.Then you can use the
IRecordStorageto get aRecordby ID. You'll also need to parse the form.And using the
IRecordServiceyou can approve records.is working on a reply...
