Umbraco Deploy on-premises and Load Balanced Environments
When we try to transfer content with deploy on-premises, I have realised that it does not refresh content correctly on slave applications. Is there a way to avoid this problem ?
Hi Mehmet - if you are on Umbraco 8, you will need to make sure you have upgraded to version 8.18 of the CMS (ideally to the latest patch release).
Without that you will be missing the resolution to this issue (fixed with this update) and I think will be leading to the problem you are encountering.
Thanks in advance,
Mehmet
Andy
Hi Andy,
Thanks for pointing this one out for me. The project is on v8.16, I will try to upgrade as soon as possible.
UPDATE: after upgrade it worked just fine. Thanks again Andy!
Regards,
Mehmet
