  • Martin Rud 261 posts 1022 karma points c-trib
    Apr 15, 2022 @ 14:01
    Martin Rud
    How to read settings from appsettings.json in a view?
    Hi forum,
    I have Googled and tried (with only errors), so now I ask here. :)
    In a view I want to read some values from appsettings.json. I have found some code that seems to be part of the solution:
    MrAppsettings.cs:
    using Microsoft.Extensions.Options;
    using Umbraco.Cms.Core.Configuration.Models;
    namespace MrAppsettings
        public class SomeClass
            private GlobalSettings _globalSettings;
            public SomeClass(IOptions<GlobalSettings> globalSettings)
                _globalSettings = globalSettings.Value;
                var smtpHost = _globalSettings.Smtp.Host;
    1) As I can read this must be registered in Startup.cs, but how?
    2) And how do I "call" the class in my cshtml views?
  • Guido Adam 23 posts 67 karma points
    Apr 15, 2022 @ 14:09
    Guido Adam
    101
    What you're doing here is DI. This is (a small) part of the solution.
    Example:
    Your appsettings.json:
    "EmailSettings": {
      "MailServer": "",
      "MailPort": ,
      "Email": "",
      "Password": "",
      "SenderName": "",
      "Sender": "",
      "SysAdminEmail": ""
    Register the service (so you can do DI) in startup.cs:
    services.Configure<EmailSettings>(configuration.GetSection("EmailSettings"));
    Settings Class:
    public class EmailSettings
      public string MailServer { get; set; }
      public int MailPort { get; set; }
      public string SenderName { get; set; }
      public string Sender { get; set; }
      public string Email { get; set; }
      public string Password { get; set; }
      public string SysAdminEmail { get; set; }
    Class, constructor and usage:
    private readonly IOptions<EmailSettings> _emailSettings;
    public EmailSender(IOptions<EmailSettings> emailSettings)
      _emailSettings = emailSettings;
    email.From.Add(new MailboxAddress(_emailSettings.Value.SenderName, _emailSetting.Value.Sender));
  • Chris Randle 85 posts 199 karma points c-trib
    Jul 16, 2024 @ 23:29
    Chris Randle
    Just to update this, personally I would inject a service. Look at @inject directive, creating a helper class that reads from the appSettings. This is referred to as "using dependency injection in a view" and you can read more about it in the Microsoft's Learn documentation.
