Umbraco 9 can't start self-contained publish... in my project
I have tried installing the NuGet template Umbraco.Cms version 9.4.3, and tried to setup a Publish profile from it.
It will be .NET 5 or .NET (6), self-contained, and x86 (x64 has also been tried), and published to a folder.
We are missing all the /Views, /App_Plugins, and /umbraco.
This can be fixed by adding the following to the .csproj-file:
Adding a valid connectionstring in appsettings.json, and publishing that, this will produce a running site on http://localhost:5000.
I have a problem; I get the following error for my site, where everything has been mirrored from this default project:
Unhandled exception. System.InvalidOperationException: No hashing type found by name SHA1
at Umbraco.Extensions.StringExtensions.GenerateHash(String str, String hashType)
at Umbraco.Extensions.StringExtensions.ToSHA1(String stringToConvert)
at Umbraco.Extensions.StringExtensions.GenerateHash(String str)
at Umbraco.Cms.Web.Common.AspNetCore.AspNetCoreHostingEnvironment.get_ApplicationId()
at Umbraco.Extensions.LoggerConfigExtensions.MinimalConfiguration(LoggerConfiguration logConfig, IHostingEnvironment hostingEnvironment, ILoggingConfiguration loggingConfiguration, IConfiguration configuration, UmbracoFileConfiguration& umbFileConfiguration)
at Umbraco.Cms.Core.Logging.Serilog.SerilogLogger.CreateWithDefaultConfiguration(IHostingEnvironment hostingEnvironment, ILoggingConfiguration loggingConfiguration, IConfiguration configuration, UmbracoFileConfiguration& umbracoFileConfig)
at Umbraco.Extensions.ServiceCollectionExtensions.AddLogger(IServiceCollection services, IHostingEnvironment hostingEnvironment, ILoggingConfiguration loggingConfiguration, IConfiguration configuration)
at Umbraco.Extensions.UmbracoBuilderExtensions.AddUmbraco(IServiceCollection services, IWebHostEnvironment webHostEnvironment, IConfiguration config)
at Website.Startup.ConfigureServices(IServiceCollection services) in C:\Users\mypath\src\Website\Startup.cs:line 43
at System.RuntimeMethodHandle.InvokeMethod(Object , Span`1& , Signature , Boolean , Boolean )
at System.Reflection.RuntimeMethodInfo.Invoke(Object , BindingFlags , Binder , Object[] , CultureInfo )
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.InvokeCore(Object instance, IServiceCollection services)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.<>c__DisplayClass9_0.<Invoke>g__Startup|0(IServiceCollection serviceCollection)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.Invoke(Object instance, IServiceCollection services)
at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.<>c__DisplayClass8_0.<Build>b__0(IServiceCollection services)
at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.UseStartup(Type startupType, HostBuilderContext context, IServiceCollection services, Object instance)
at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.<>c__DisplayClass13_0.<UseStartup>b__0(HostBuilderContext context, IServiceCollection services)
at Microsoft.Extensions.Hosting.HostBuilder.CreateServiceProvider()
at Microsoft.Extensions.Hosting.HostBuilder.Build()
at Website.Program.Main(String[] args) in C:\Users\mypath\src\Website\Program.cs:line 10
I can't figure out what it is.
I can run the site from Visual Studio's IIS, but I can't run the published version.
It looks like it is missing its ApplicationId from the lines
... at Umbraco.Extensions.StringExtensions.GenerateHash(String str)
What could this be?
I've deleted my entire /bin and /obj folder, but it doesn't help.
I have tried publishing to my desktop, but still the same error.
Umbraco.Cmsversion 9.4.3, and tried to setup a Publish profile from it. It will be .NET 5 or .NET (6), self-contained, and x86 (x64 has also been tried), and published to a folder.We are missing all the
/Views,/App_Plugins, and/umbraco.This can be fixed by adding the following to the
.csproj-file:``` ...
appsettings.json, and publishing that, this will produce a running site onhttp://localhost:5000.I have a problem; I get the following error for my site, where everything has been mirrored from this default project:
Unhandled exception. System.InvalidOperationException: No hashing type found by name SHA1 at Umbraco.Extensions.StringExtensions.GenerateHash(String str, String hashType) at Umbraco.Extensions.StringExtensions.ToSHA1(String stringToConvert) at Umbraco.Extensions.StringExtensions.GenerateHash(String str) at Umbraco.Cms.Web.Common.AspNetCore.AspNetCoreHostingEnvironment.get_ApplicationId() at Umbraco.Extensions.LoggerConfigExtensions.MinimalConfiguration(LoggerConfiguration logConfig, IHostingEnvironment hostingEnvironment, ILoggingConfiguration loggingConfiguration, IConfiguration configuration, UmbracoFileConfiguration& umbFileConfiguration) at Umbraco.Cms.Core.Logging.Serilog.SerilogLogger.CreateWithDefaultConfiguration(IHostingEnvironment hostingEnvironment, ILoggingConfiguration loggingConfiguration, IConfiguration configuration, UmbracoFileConfiguration& umbracoFileConfig) at Umbraco.Extensions.ServiceCollectionExtensions.AddLogger(IServiceCollection services, IHostingEnvironment hostingEnvironment, ILoggingConfiguration loggingConfiguration, IConfiguration configuration) at Umbraco.Extensions.UmbracoBuilderExtensions.AddUmbraco(IServiceCollection services, IWebHostEnvironment webHostEnvironment, IConfiguration config) at Website.Startup.ConfigureServices(IServiceCollection services) in C:\Users\mypath\src\Website\Startup.cs:line 43 at System.RuntimeMethodHandle.InvokeMethod(Object , Span`1& , Signature , Boolean , Boolean ) at System.Reflection.RuntimeMethodInfo.Invoke(Object , BindingFlags , Binder , Object[] , CultureInfo ) at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.InvokeCore(Object instance, IServiceCollection services) at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.<>c__DisplayClass9_0.<Invoke>g__Startup|0(IServiceCollection serviceCollection) at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.Invoke(Object instance, IServiceCollection services) at Microsoft.AspNetCore.Hosting.ConfigureServicesBuilder.<>c__DisplayClass8_0.<Build>b__0(IServiceCollection services) at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.UseStartup(Type startupType, HostBuilderContext context, IServiceCollection services, Object instance) at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.<>c__DisplayClass13_0.<UseStartup>b__0(HostBuilderContext context, IServiceCollection services) at Microsoft.Extensions.Hosting.HostBuilder.CreateServiceProvider() at Microsoft.Extensions.Hosting.HostBuilder.Build() at Website.Program.Main(String[] args) in C:\Users\mypath\src\Website\Program.cs:line 10I can't figure out what it is.
I can run the site from Visual Studio's IIS, but I can't run the published version. It looks like it is missing its
ApplicationIdfrom the lines... at Umbraco.Extensions.StringExtensions.GenerateHash(String str) at Umbraco.Cms.Web.Common.AspNetCore.AspNetCoreHostingEnvironment.get_ApplicationId()What could this be?
/binand/objfolder, but it doesn't help. I have tried publishing to my desktop, but still the same error.What is wrong here?
Looks like the issue stems from this line of code.
"AppDomainAppId"is not set in the variablelogConfig.Error found:
Umbraco cannot make a Publish with .NET (6) as expected. It can run on a Visual Studio's
F5, but it cannot make a Publish.Downgrading to .NET 5 resolves the error.
@Mods, can you close this ticket? (Yes, it is I who is OP)
