  • Jason Picard 4 posts 74 karma points
    May 04, 2022 @ 16:46
    Jason Picard
    Umbraco 9 appsettings.json not working?
    I am trying to make changes to the validElements section here:
    "Umbraco": {
        "CMS": {
          "RichTextEditor": {
            "ValidElements": "+a[id|style|rel|rev|hreflang|dir|lang|tabindex|accesskey|type|href|target|class],-abbr[class|style],-address[id|dir|class|style|aria-*|role|data-*],animate[*],animateMotion[*],animateTransform[*],area[shape|coords|href|alt|target|class],-article[id|dir|class|style|aria-*|role|data-*],-aside[id|dir|class|style|aria-*|role|data-*],audio[class|style|*],-b/-strong[class|style],-bdo[class],-blockquote[id|dir|style|aria-*|role|class],br[class],button[id|class|style|*],canvas[id|class|style|alt|aria-*|role|data-*|width|height|*],caption[id|lang|dir|class|style],circle[*],-cite[class|style],clipPath[*],-code[class|style],datalist[id|class|style|*],dd[id|class|title|style|dir|lang],defs[*],desc[*],-details[id|dir|class|style|aria-*|role|open],-dfn[class],discard[*],-div[id|dir|class|style|aria-*|role|data-*],dl[id|class|title|style|dir|lang],dt[id|class|title|style|dir|lang],ellipse[*],feBlend[*],feColorMatrix[*],feComponentTransfer[*],feComposite[*],feConvolveMatrix[*],feDiffuseLighting[*],feDisplacementMap[*],feDistantLight[*],feDropShadow[*],feFlood[*],feFuncA[*],feFuncB[*],feFuncG[*],feFuncR[*],feGaussianBlur[*],feImage[*],feMerge[*],feMergeNode[*],feMorphology[*],feOffset[*],fePointLight[*],feSpecularLighting[*],feSpotLight[*],feTile[*],feTurbulence[*],-fieldset[id|class|style|*],figcaption[class|style],-figure[id|dir|class|style|aria-*|role|data-*],filter[*],foreignObject[*],-form[id|class|style|*],g[*],-h1[id|dir|class|style],-h2[id|dir|class|style],-h3[id|dir|class|style],-h4[id|dir|class|style],-h5[id|dir|class|style],-h6[id|style|dir|class|style],hatch[*],hatchpath[*],hr[class|style],-i/-em[class|style],iframe[id|class|style|alt|aria-*|role|data-*|width|height|loading|src|srcdoc|allow=fullscreen|*],image[*],img[id|dir|lang|longdesc|usemap|style|class|src|alt|width|height|umbracoorgwidth|umbracoorgheight|onresize|onresizestart|onresizeend|rel|data-*],input[id|class|style|*],label[id|class|style|*],-legend[id|class|style|*],-li[id|class|style],line[*],linearGradient[*],map[id|name|class|style|aria-*|role|data-*],marker[*],mask[*],metadata[*],meter[id|class|style|*],mpath[*],-nav[id|dir|class|style|aria-*|role|data-*],-ol[id|class|reversed|start|style|type],optgroup[id|class|style|*],option[id|class|style|*],output[id|class|style|*],-p[id|style|dir|class],path[*],pattern[*],picture[id|class|style|alt|aria-*|role|data-*|width|height|loading|*],polygon[*],polyline[*],-pre[class|style],progress[id|class|style|*],-q[class|style],radialGradient[*],rect[*],-section[id|dir|class|style|aria-*|role|data-*],-select[id|class|style|*],set[*],-small[class|style],source[*],-span[class|style],stop[*],-strike[class|style],-sub[style|class],-summary[id|class|style|aria-*|role],-sup[style|class],-svg[id|class|style|alt|aria-*|role|data-*|*],switch[*],symbol[*],-table[id|class|style|dir|lang|*],tbody[id|class],td[id|lang|dir|class|colspan|rowspan|style|scope],text[*],textarea[id|class|style|*],textPath[*],tfoot[id|class],-th[id|lang|dir|class|colspan|rowspan|style|scope],thead[id|class],title[*],-tr[id|class|style|dir|lang],track[*],tspan[*],-u[class|style],-ul[id|class|style],use[*],video[id|class|style|alt|aria-*|role|data-*|*],view[*]",
    "InvalidElements": "font"},
    some HTML tags are being stripped out even though they have been placed in the validElements section as seen in the code above. This is quite frustrating as it is holding us back from further development. We never had this problem in previous versions using .config files.
    May 06, 2022 @ 09:41
    Dave Woestenborghs
    HI Jason,
    Which html tags are not working ?
    Dave
    May 06, 2022 @ 10:38
    Jason Picard
    Hi Dave,
    Thanks for getting back to me about this question. So far we have noticed these tags are being stripped from the HTML upon saving
    May 06, 2022 @ 10:39
    Jason Picard
    Sorry I didn't realize I had to place the tags in the code sample area, here are the tags so far.
    <aside>, <nav>, <b>, <i>
    May 06, 2022 @ 10:45
    Dave Woestenborghs
    Hi Jason,
    I see all these elements in your config starting with a -
    Could that be the issue ? I'm not an expert in tinyMce config.
    Dave
    May 06, 2022 @ 11:00
    Jason Picard
    Hi Dave,
    That is exactly what I thought initially, but apparently the - sign has an effect on what attributes can be applied to the tag, not whether the tag is considered valid or not. If the tag is in there it is considered valid. You can include a section in the appsettings.config for InvalidElements as well which allows you to exclude certain tags.
