I populate a dropdown with the Json in the following view. Note the ng-options:
<select ng-model="model.value" ng-options="sub.SubID as sub.Title for sub in subscriptions">
<option value="">-- choose subscription --</option>
</select>
The dropdown populates with the title being displayed, but the values are sequential and not the true SubIDs. For example, the first item in the Json has a SubID of "1", but the value in the dropdown is "0". However, when selected, the correct SubID is injected into the macro. Here is the HTML:
Unfortunately, when I re-open the macro parameters, the dropdown box resets.
If I change the ng-options to the following:
<select ng-model="model.value" ng-options="sub.Title for sub in subscriptions track by sub.SubID">
</select>
when I select an option, confirm it, and re-open the macro parameters, the dropdown retains the selection as it should, and the dropdown values correspond to the SubID. However, now, the entire Json object is being injected into the macro, as seen in the HTML:
Thank you for the reply. Actually, I am trying to capture the SubID. I have already tried this code:
track by sub.SubID
It didn't have any effect.
Again, when I use
The SubID only is saved in the model and injected into the macro correctly, but the dropdown values aren't those of the SubID and the dropdown resets when reloaded.
However, when I use
track by sub.SubID
The dropdown values are set to the SubID values the dropdown retains it's selection when reloaded, but the entire Json object is saved in the Umbraco model and is injected into the macro, which breaks it.
I need it to do both: save only the SubID in the model and inject only the SubID into the macro, and retain the dropdown selection when reloaded (I don't care if the dropdown values are correct so long as it works as needed. But I suspect this has something to do with my problem.)
<select ng-model="chosenSub" ng-change="newSub()" ng-options="sub.Title for sub in subscriptions track by sub.SubID">
</select>
As you can see, I have it tracking by the SubID, I set the model to custom parameter 'chosenSub', and I added an 'ng-change' function call.
Here is my controller:
if ($scope.model.value != null) {
angular.forEach($scope.subscriptions, function (value, key) {
if ($scope.model.value == value.SubID) {
$scope.chosenSub = value;
$scope.newSub = function () {
$scope.model.value = $scope.chosenSub.SubID;
So basically, I check if the model has a value. If it does, I iterate through the Json collection to find a match on the SubID. Once found, I set the custom paramter 'chosenSub' equal to the Json object. This allows the dropdown to retain the selection on reload. And then, the onchange function sets the model value to the SubID of the chosen item in the dropdown. This allows just the SubID to be injected into the macro.
I don't know if this is the best way to do this, but I can't find any other way.
Custom Parameter Editor Issue
I have a custom parameter editor that consists of a dropdown that is populated from a Json collection:
[ {"SubID":1,"Title":"Agenda"}, {"SubID":2,"Title":"Handbook"}, {"SubID":3,"Title":"Members"}, {"SubID":4,"Title":"Vacancies"}, {"SubID":6,"Title":"eachers"} ]
In my controller, I have this line. :
What I need here is for the dropdown to retain the value AND only the SubID to be injected into the HTML. What am I doing wrong?
Are you trying to capture the
titleonly? Try using this for yourng-optionsattribute:Here's a CodePen.
I don't find the vernacular for
ng-optionsto be that friendly. You'll receive a better explanation for this behavior if you read the documentation.Thank you for the reply. Actually, I am trying to capture the SubID. I have already tried this code:
Again, when I use
However, when I use
Sorry for misreading your original request!
That's very odd indeed. The first example you provided works in my CodePen. This is my new
ng-optionsattribute value:I'll try to test this inside of Umbraco next. I'm sorry I wasn't able to help more!
No worries. Thank you for any help you can give. This one has been driving me bonkers! I am considering coding around it.
In my manifest file, I have tried changing the 'valuetype' for the editor, and it doesn't seem to change anything.
I was able to find a solution/work around.
Here is my updated view:
