  • Harsheet 4 posts 24 karma points
    May 11, 2022 @ 01:10
    Harsheet
    Removed AD authentication - Developer section not working
    Hi guys,
    I just removed AD authentication from the site. I removed everything that was added for Azure Active Directory Authentication.
    Now I can login to backoffice but I am getting unauthorized error on Developer section.
    Any help appreciated.
    May 31, 2022 @ 07:11
    Harsheet
    Adding a solution to this problem if someone is looking out a similar one.
    The issue happened because of some web api routes in webApiConfig.cs
    You can check the routes in this file and fix the issue
