  • Roman Kalius 6 posts 76 karma points
    May 16, 2022 @ 10:47
    Roman Kalius
    Custom validation not working
    hi I have problem with custom validation in js plugin:
    my html:
    <div id="u7dtgSliderEvent" ng-controller="u7dtgSliderEvent.editorController"> <input type="hidden" ng-model="validationTest" val-property-validator="validateMandatory" />
    my js:
    angular.module("umbraco") .controller("u7dtgSliderEvent.editorController", function ($scope, $timeout) {
            $scope.validationTest = null;
            $scope.validateMandatory = function () {
                return {
                    isValid: false,
                    errorMsg: "Value cannot be empty",
                    errorKey: "required"
    validateMandatory function is executed ones on plugin load, return false, but nothing happend on saving data. What i make wrong?
    i took this example from https://github.com/umbraco/Umbraco-CMS/tree/9290f61f9485c5bef0aa9a95e05e8acefa9ce221/src/Umbraco.Web.UI.Client/src/views/propertyeditors/tags
    but it doesnt work.
    Can somebody help my?
  • Andrei 15 posts 99 karma points
    Jun 02, 2022 @ 12:28
    Andrei
    I just hit the same issue. When I click save on the page, I briefly get the error message, but the page still submits and saves. Did you find a solution?
  • Kevin Ferati 1 post 71 karma points
    Oct 12, 2022 @ 10:15
    Kevin Ferati
    Have you found any solution regarding this issue ? I just ran on it (using Umbraco 10.2)
  • Pedro Mendes 53 posts 258 karma points
    Nov 18, 2022 @ 02:39
    Pedro Mendes
    I know this is somewhat late, but I think the OP wasn't checking the correct branch (it appears he was checking something prior to v9).
    Anyway, if you take a look at this
    https://github.com/umbraco/Umbraco-CMS/blob/v9/dev/src/Umbraco.Web.UI.Client/src/common/directives/components/tags/umbtagseditor.directive.js
    (which is used in the new tag editor https://github.com/umbraco/Umbraco-CMS/blob/v9/dev/src/Umbraco.Web.UI.Client/src/views/propertyeditors/tags/tags.html)
    I believe you'll have to "hook" your validation to the validateMandatory inside your controller, not the view.
