I am trying to create a custom attribute that uses umbraco dictionary value.
I do not know how to get the UmbracoHelper instance as I don't thunk a custom attribute supports dependency injection.
UmbracoHelper
Any thoughts how to get UmbracoHelper in other way than DI?
This is what I have:
[AttributeUsage(AttributeTargets.Method | AttributeTargets.Property | AttributeTargets.Field | AttributeTargets.Parameter, AllowMultiple = false)] public sealed class UmbracoDisplayAttribute : DisplayNameAttribute { private readonly UmbracoHelper _umbracoHelper; // <- this value is missing // This is a positional argument public UmbracoDisplayAttribute(string dictionaryKey) : base(dictionaryKey) { } public override string DisplayName { get { return _umbracoHelper != null ? _umbracoHelper.GetDictionaryValue(base.DisplayName) : string.Empty; } } }
Is there any way of getting UmbracoHelper without DI in Umbraco 9?
Hi nickornotto,
Dependency injection in attributes is not possible. This not a Umbraco thing but .NET thing.
You could retrieve the dependency in your attribute using the service locator pattern.
[AttributeUsage(AttributeTargets.Method | AttributeTargets.Property | AttributeTargets.Field | AttributeTargets.Parameter, AllowMultiple = false)] public sealed class UmbracoDisplayAttribute : DisplayNameAttribute { // This is a positional argument public UmbracoDisplayAttribute(string dictionaryKey) : base(dictionaryKey) { } public override string DisplayName { get { var umbracoHelper = new HttpContextAccessor().HttpContext.RequestServices.GetService<UmbracoHelper>(); return umbracoHelper != null ? umbracoHelper.GetDictionaryValue(base.DisplayName) : string.Empty; } } }
Bril, thank you!
How to get UmbracoHelper in a custom attribute without DI?
UmbracoHelperinstance as I don't thunk a custom attribute supports dependency injection.Any thoughts how to get
UmbracoHelperin other way than DI?This is what I have:
Hi nickornotto,
Bril, thank you!
