  • Anna 15 posts 109 karma points
    May 19, 2022 @ 08:56
    Anna
    Element type not generated with models builder
    Hello!
    I have an element type that I need to use in a Nested Content property.
    However when I generate the models with models builder, the model for the element type is not generated, resulting in a build error.
    The Element type: enter image description here
    The Document type that uses the nested content proerty: enter image description here
    The build error comes because the faqQuestion element type is not generated: enter image description here
    Is there some setting or something that needs to be done so that also the element types get generated? Hope somebody can help me.
  • Nik 1567 posts 7015 karma points MVP 6x c-trib
    May 19, 2022 @ 09:16
    Nik
    101
    Hey Anna,
    Are you sure the model isn't being generated? Or is it that the file isn't being included in your Visual Studio project?
    Depending on how your project is set up, it's very possible that new model files aren't being automatically included so it's worth double checking.
    Nik
    May 19, 2022 @ 10:00
    Anna
    Aah, face palm!
    That was it! It wasn't included in the project, but hidden :)
    Thank you :)
    Anna
    May 19, 2022 @ 11:50
    Nik
    No problem, the amount of time I've lost to that same issue is absolute madness! :-D
