  • Yuvraj Singh 32 posts 142 karma points
    May 27, 2022 @ 13:21
    Yuvraj Singh
    Not work in Umbraco 8.9.0 Url.GetCropUrl
    This method does not work in Umbraco 8.9.0
    Can anybody help me?
  • Kevin Meilander 82 posts 408 karma points c-trib
    May 31, 2022 @ 19:22
    Kevin Meilander
    What do you mean by does not work?
    Like does it throw an error (if so what is the error), or will it give you an image url, but the image wont show up with the crop sizes you want?
    If it's the image cropping isn't working (so the URL is right, but the image isn't lookng right), be sure to check your /config/imageprocessor/security.config settings to make sure the imageprocessor has access to where your media is stored.
