Is there a way to serialise IPublishedContent to JSON in Umbraco 9?
I am unable to serialise a content with nested content property in v9 straight to JSON because of Content property self referencing, eg:
JsonSerializationException: Self referencing loop detected for
property 'ContentType' with type
'Umbraco.Cms.Core.Models.PublishedContent.PublishedContentType'. Path
'SearchResult[0].NestedContentItem[0].Item.ItemNc[0].Price[0].ContentType.PropertyTypes[0]'.
Is there any way of facilitating the serialisation other than map to custom model?
If you are using the Contentment package, (yup, I'm plugging my own package), then there is an undocumented feature to serialize IPublishedContent objects.
Then in your controller code, however you are serializing the object to JSON, you can assign the ContractResolver like so...
SerializerSettings = new JsonSerializerSettings
ContractResolver = new Umbraco.Community.Contentment.Web.Serialization.PublishedContentContractResolver(),
Hi Nick,
IPublishedContentobjects.If you aren't using Contentment, that's cool - if you want to copy/paste the source code, it's here: https://github.com/leekelleher/umbraco-contentment/blob/3.3.1/src/Umbraco.Community.Contentment/Web/Serialization/PublishedContentContractResolver.cs
ContractResolverlike so...I hope this helps?
- Lee
Fantastic! It's a great help.
I didn't check what's the performance with a larger number of items but will report here if there is any issue later.
Thanks!
