Is there a possible integration between umbraco and nopcommerce
Is there a possible integration between umbraco's last version and nopcommerce?
I asked this to a support member but he was not sure. Has anyone tried with the latest version of umbraco(9) with nopcommerce? I searched this and saw that there was a post from 2018 (when umbraco has the previous version) and the links are broken now. Thank you
If you don't mind using different subdomains for each you can create 2 different websites and the 2 won't interfere in any way, otherwise I'm not sure.
So what I mean is:
www.yourdomain.com - runs your blog created in Umbraco X
shop.yourdomain.com - runs the shop in nopcommerce or other shop software
In the menu and you link from www to the shop and visa versa.
However when doing:
www.yourdomain.com
www.yourdomain.com/shop
You have them running in the same virtual space and have to make sure the routing of each doesn't interfere with the other.
Is there a possible integration between umbraco's last version and nopcommerce? I asked this to a support member but he was not sure. Has anyone tried with the latest version of umbraco(9) with nopcommerce? I searched this and saw that there was a post from 2018 (when umbraco has the previous version) and the links are broken now. Thank you
Eser Cihan
So what I mean is:
However when doing:
