  • Sean Håkansson 68 posts 204 karma points
    Jun 02, 2022 @ 10:14
    Sean Håkansson
    Umbraco Forms not showing text for labels?
    Current installed version of Umbraco Forms: 9.4.1
    It seems the checkbox label/text is not showing, I think it should try to load it from the name (which isn't ideal either and should have seperate textfield in settings)
    Screen shot 1 Settings open Rendered on page
    I installed umbraco forms via nuget, and not via ZIP if that makes any difference?
    Jun 02, 2022 @ 12:27
    Dave Woestenborghs
    Hi Sean,
    The label is rendering as far as I can see. You named it checkbox and on your screenshot it is also showing checkbox.
    dave
    Jun 02, 2022 @ 12:38
    Sean Håkansson
    Thanks for reply Dave!
    But shouldn't the label be rendered after the checkbox? Right now its rendered as a "text" input label, not beside it. Is that something I have to customize myself?
    It seems to work fine when I use a checkbox/radio list? Why wouldnt we have the same behaviour on single checkboxes?
    enter image description here enter image description here enter image description here
    Jun 02, 2022 @ 12:48
    Dave Woestenborghs
    Hi Sean,
    You can fully customize the look and feel of forms. Even per field type : https://our.umbraco.com/documentation/Add-ons/UmbracoForms/Developer/Custom-Markup/
    Dave
