Umbraco Forms - Create custom FieldPreValueSourceType using picked Content node
I am attempting to create a custom prevalue source - but I am looking to get data from a property on the node, rather than using children nodes as the source of the prevalues.
Here is what I have so far:
using System;
using Microsoft.Extensions.Logging;
using Rwater.Services;
using Umbraco.Cms.Core;
using Umbraco.Forms.Core;
using Umbraco.Forms.Core.Models;
public class FormPrevaluesSourceNode : FieldPreValueSourceType
private readonly ILogger _logger;
private readonly IPublishedContentQuery _publishedContentQuery;
[Umbraco.Forms.Core.Attributes.Setting(name: "Form Prevalues Source Node",
Alias = "SourceNodeId",
Description = "Node holding the Options desired.",
View = "pickers.content")]
public int SourceNodeId { get; set; }
public FormPrevaluesSourceNode(IPublishedContentQuery publishedContentQuery,
ILogger<FormPrevaluesSourceNode> logger)
_logger = logger;
_publishedContentQuery = publishedContentQuery;
this.Id = new Guid("0E4D4E2B-56E1-4E86-84E4-9A0A6051B57C");
this.Name = "Content-defined Form Prevalues Source Node";
this.Description = "Select a node of type 'FormPrevaluesSourceNode'";
this.Group = "Custom";
this.Icon = "icon-science";
public override List<PreValue> GetPreValues(Field field, Form form)
List<PreValue> result = new List<PreValue>();
try
var node = _publishedContentQuery.Content(SourceNodeId);
if (node != null)
int sort = 0;
var preValSource = new Models.FormPrevaluesSourceNode(node, null);
foreach (var prevalue in preValSource.PreValues)
PreValue pv = new PreValue();
pv.Id = sort == 0 ? SourceNodeId : sort;
pv.Value = prevalue.StoredValue;
pv.SortOrder = sort;
result.Add(pv);
sort++;
catch (Exception ex)
_logger.LogError($"Unable to get options from FormPrevaluesSourceNode #{SourceNodeId}", ex);
return result;
public override List<Exception> ValidateSettings()
List<Exception> exs = new List<Exception>();
if (SourceNodeId == default(int))
exs.Add(new Exception("'SourceNodeId' setting not filled out’"));
return exs;
and
public class FormsComposer : IComposer
public void Compose(IUmbracoBuilder builder)
builder.WithCollectionBuilder<FieldPreValueSourceCollectionBuilder>()
.Add<FormPrevaluesSourceNode>();
But when I compile, I am getting this error:
Cannot consume scoped service 'Umbraco.Cms.Core.IPublishedContentQuery' from singleton 'MyNamespace.FormPrevaluesSourceNode'.)
Is there a singleton-accessible way to get an IPublishedContent from the int Node Id returned from the Setting?
Hi Heather - I think in this context you need to inject IPublishedContentQueryAccessor, which can be injected into singletons, and from there you have a method available TryGetValue that you can use to get an instance of IPublishedContentQuery.
and
TryGetValuethat you can use to get an instance ofIPublishedContentQuery.Hope that helps.
Andy
Thanks, Andy,
Do you know if there is a preference between using
IPublishedContentQueryor usingUmbracoContextFactory?example:
This helped me with a dependency injection scoping struggle, thanks!
No, not sure, but I don't think there'd be any fundamental difference here (i.e. in the end you'd get the same object back to query against).
I was just wondering if one or the other was more performant, or more stable, etc.
