When I now folder publish from Visual studio, then it ignores *.html files from the App_Plugins folder...
It works fine in 9.4.3.
I have now tried to install a clean 9.4.3 and a clean 9.5.0..
9.4.3 folder publish works fine. Html copied to deploy folder..
9.5.0 folder publish ignores the html files from my test project..
Anyone that have tried that ?
I've already replied on the github issue. But I'm experiencing the same thing. This also happens when publishing in a (Linux) docker container or Azure Pipeline
I've checked my .proj file and all the .html files are included there, but they are not published.
For testing I ran it my project in a docker locally, and indeed the .html files aren't published in my docker container.
Umbraco 9.5.0 Visual studio publish issue
I have a strange issue..
After I have updated to Umbraco 9.5.0...
It works fine in 9.4.3. I have now tried to install a clean 9.4.3 and a clean 9.5.0.. 9.4.3 folder publish works fine. Html copied to deploy folder.. 9.5.0 folder publish ignores the html files from my test project.. Anyone that have tried that ?
Edit the project file and make sure App_Plugins is included:
