Hi!, Appreciate your help here, I'm using media picker to upload SVG file and it is under a list view item.
But the svg file is not displayed in the front end of the website.
What Ive been doing wrong? Thanks in advanced.
What is printed in the source in the URL field? Perhaps the type of the image?
If so you need to get the URL property of the value you retrieve with item.Value("image")
item.Value("image")
Hi Ambert, Thank you for your reply! My bad, there is no source in the URL field, I followed this one: https://our.umbraco.com/Documentation/Fundamentals/Backoffice/Property-Editors/Built-in-Property-Editors/Media-Picker/ and the svg file is now showing in the front end.
Results:
Thanks!
Nice that you fixed it! Cheers!
Btw dont forget to add a null check for your link, as that can be null aswell ;-)
Yes, thanks for that one!
SVG using Media Picker
item.Value("image")Hi Ambert, Thank you for your reply! My bad, there is no source in the URL field, I followed this one: https://our.umbraco.com/Documentation/Fundamentals/Backoffice/Property-Editors/Built-in-Property-Editors/Media-Picker/ and the svg file is now showing in the front end.
Results:
Thanks!
