Also notified you on Slack, but this way other people can also find the answer to this question.
With Examine v3, it seems like you'll have to convert the values to a dictionary, add/change values and then set the valueset against the event arguments.
Examine, Transforming index values in V10
Anyone know how to transform your Examine index in V10?
A breaking change was introduced which makes ValueSet immutable.
TryAdd to add new items to index no longer works. The documentation still claims it can be used:
https://our.umbraco.com/documentation/reference/searching/examine/examine-events#adding-the-path-of-the-node-as-a-searchable-field-into-the-index
However you can see the breaking change here:
https://github.com/umbraco/Umbraco-CMS/pull/12307
Marc
You can see this being used in the tests that are present in the Examine v3 code base: https://github.com/Shazwazza/Examine/blob/release/3.0/src/Examine.Test/Examine.Lucene/Index/LuceneIndexTests.cs#L328
Just to add to this, you need to use SetValues to update the index:
