V10 - Need help, Can't get ajax fetch post working using SurfaceController
I'm having trouble to get this work. I'm trying to do ajax post using javascript fetch, and always get status error 400. It works with ApiController but not with SurfaceController.
using Microsoft.AspNetCore.Mvc;
using umb10.Models;
using Umbraco.Cms.Core.Cache;
using Umbraco.Cms.Core.Logging;
using Umbraco.Cms.Core.Routing;
using Umbraco.Cms.Core.Services;
using Umbraco.Cms.Core.Web;
using Umbraco.Cms.Infrastructure.Persistence;
using Umbraco.Cms.Web.Website.Controllers;
namespace umb10.Controllers
public class TestController : SurfaceController
private readonly IUmbracoContextAccessor umbracoContextAccessor;
private readonly IUmbracoDatabaseFactory databaseFactory;
private readonly ServiceContext services;
private readonly AppCaches appCaches;
private readonly IProfilingLogger profilingLogger;
private readonly IPublishedUrlProvider publishedUrlProvider;
public TestController(IUmbracoContextAccessor umbracoContextAccessor, IUmbracoDatabaseFactory databaseFactory, ServiceContext services, AppCaches appCaches, IProfilingLogger profilingLogger, IPublishedUrlProvider publishedUrlProvider) : base(umbracoContextAccessor, databaseFactory, services, appCaches, profilingLogger, publishedUrlProvider)
this.umbracoContextAccessor = umbracoContextAccessor;
this.databaseFactory = databaseFactory;
this.services = services;
this.appCaches = appCaches;
this.profilingLogger = profilingLogger;
this.publishedUrlProvider = publishedUrlProvider;
public IActionResult GetPartialView()
return PartialView("~/Views/Partials/Test.cshtml");
[HttpPost]
public IActionResult PostDummyData(PostModel postModel)
return Ok(postModel);
PostModel.cs
namespace umb10.Models
public class PostModel
public string Title { get; set; }
public string Body { get; set; }
public int UserId { get; set; }
Testo Api Controller
using umb10.Models;
using Umbraco.Cms.Web.Common.Controllers;
public class TestoController : UmbracoApiController
return Content("~/Views/Partials/Test.cshtml");
[HttpPost]
Validation of Anti forgery token is enabled by default for v9/v10 now, so it returns 400 cuz you don't have anti forgery token in your request.
You can disable it if you will add the ignore attribute:
[IgnoreAntiforgeryToken]
@Andrey I added [IgnoreAntiforgeryToken] as you mentioned, and now hits the function on the server end, but my postModel is null. Something isn't working as it should. The passed data looks fine, and the data is the same as I send for api controller example which are passed fine.
Here is the code, please help. Kind regards.
Home.chstml
TestController.cs
PostModel.cs
Validation of Anti forgery token is enabled by default for v9/v10 now, so it returns 400 cuz you don't have anti forgery token in your request. You can disable it if you will add the ignore attribute: [IgnoreAntiforgeryToken]
You can read a details here: https://our.umbraco.com/documentation/reference/routing/surface-controllers
I managed to get it working.
Here is the working solution if you choose to Ignore AntiforgeryToken: Added extra [FromBody]
I'll also add link to this thread: https://github.com/umbraco/UmbracoDocs/issues/3242
If you want to pass AntiforgeryToken with your ajax post request:
In Home.cshtml add:
In fetch pass new header RequestVerificationToken like this:
In TestController.cs (surface controller as of v9 SurfaceControllers now by default have the anti-forgery check)
I have alse needed to do the following, depending how your model is created/used
