Hi folks :)
I had some problem with integration umbraco 7.14 with Azure Active Directory. I followed @Shawazza article: Configuring Azure Active Directory login with Umbraco Members and everything supposed to be clear but after deploying to environments I had strange situation with cookies, on one environment cookie aiuser and ASP.NETSession id is missing and due to this problem I can't get into backoffice. It is so confusing because on the other one everything is working. Maybe someone has similar problem ?
Umbraco and Azure Active Directory Integration
Hi folks :) I had some problem with integration umbraco 7.14 with Azure Active Directory. I followed @Shawazza article: Configuring Azure Active Directory login with Umbraco Members and everything supposed to be clear but after deploying to environments I had strange situation with cookies, on one environment cookie aiuser and ASP.NETSession id is missing and due to this problem I can't get into backoffice. It is so confusing because on the other one everything is working. Maybe someone has similar problem ?
