  • Robert Johnston 16 posts 106 karma points
    Jul 18, 2022 @ 23:13
    Robert Johnston
    Is it possible to render a blocklist inside of another block list?
    Good afternoon everyone, I'm trying to see if I can render a nested blocklist inside of another. I am able to this with a blocklist that contains a single type of block. I would like to do this with a blocklist that contains multiple types of blocks.
    For example I'm working on a block that will have two sections a content column for my blocklist and an aside column for a grid editor so I can utilize macros in my aside (sub nav, etc..).
    I'm unable to get the nested blocklist to render at all.
    Any ideas? Thanks in advance.
  • Huw Reddick 1932 posts 6722 karma points MVP 3x c-trib
    Jul 19, 2022 @ 12:45
    Huw Reddick
    Yes, it is possible to do this. IIRC, I created views under Partials\blocklist to do this. I will dig out my code later and see if I can remember what I did.
    Jul 19, 2022 @ 22:08
    Robert Johnston
    Awesome, thank you very much!
    Jul 20, 2022 @ 00:18
    Robert Johnston
    I got it, it's amazing what happens when you use the proper helper. I tried this with the ModelsBuilder helper and got it to work.
    Thank you again!
    Jul 20, 2022 @ 05:28
    Huw Reddick
    Glad you sorted it 🙂
  • Craig100 1136 posts 2523 karma points c-trib
    Jun 13, 2023 @ 14:00
    Craig100
    I don't see the answer here. Any clue would be helpful as I'm trying to nest a BlockList inside a BlockGrid item.
    Thanks.
    Jun 16, 2023 @ 16:48
    Robert Johnston
    Craig100,
    I'll go back and see what I was working on at the time, what version of Umbraco are you using?
    Jun 16, 2023 @ 18:31
    Craig100
    Thanks Robert. It was 10.5.1. I've sorted it out now but it might be useful for others who chance by :)
    Jun 16, 2023 @ 21:58
    Robert Johnston
    So after looking back, this was for a Umbraco 10.1 before the Block Grid Editor which would do this differently.
    My Block (I called it Macro Aside):
    contentBlocks: Used a Block List Editor
    The I had asideContent with a Grid Layout Editor
    Here is what I used in my view:
    @inherits Umbraco.Cms.Web.Common.Views.UmbracoViewPage<Umbraco.Cms.Core.Models.Blocks.BlockListItem>;
    @using ContentModels = Umbraco.Cms.Web.Common.PublishedModels;
    @using Umbraco.Cms.Core.Models;
    @using Umbraco.Cms.Core.Models.Blocks;
        var content = (ContentModels.MacroAside)Model.Content;
        var settings = (ContentModels.MacroSettings)Model.Settings;
        var contain = settings.Value<bool>("inContainer") ? "container-lg" : "container-fluid";
        var blocks = content.ContentBlocks;
    <section class="section">
        <div class="@contain">
            <div class="row">
                <div class="col-md-8">
                    @Html.GetBlockListHtml(content.ContentBlocks)
                <div class="col-md-4">
                    @Html.GetGridHtml(content, "asideContent", "grid-bootstrap-fluid")
    </section>
    Jun 16, 2023 @ 22:22
    Craig100
    Ah, cool.
    Mine turned out to be using the non-ModelsBuilder method when I should have used the ModelsBuilder method!
    I'd used:-
    @Html.GetBlockListHtml(Model.Content.AccordionItems, "accordionItem")
    When it should have just been:-
    @Html.GetBlockListHtml(Model.Content.AccordionItems)
    Anyway, all's well that ends well, as they say ;)
