  • Ross Ekberg 131 posts 382 karma points
    Jul 20, 2022 @ 14:25
    Ross Ekberg
    Backoffice Routing Not Found
    I have a backoffice property editor that is a dropdown list that is meant to populate from a database. Here is the plugin controller, saved in the App_Code folder:
    namespace My.Controllers
        public class Subscription
            public int SubID { get; set; }
            public string Title { get; set; }
        [Umbraco.Web.Mvc.PluginController("My")]
        public class SubscriptionPickerAPIController : UmbracoAuthorizedJsonController
            public string GetAll()
                List<Subscription> subs = new List<Subscription>();
                string conn = System.Configuration.ConfigurationManager.ConnectionStrings["WebSubscriptionsEntities"].ToString();
                conn = conn.Substring(conn.IndexOf("\"") + 1);
                conn = conn.Substring(0, conn.IndexOf("\""));
                using (SqlConnection connection = new SqlConnection(conn))
                    connection.Open();
                    SqlCommand command = new SqlCommand("Select * from Subscriptions order by Title", connection);
                    using (SqlDataReader reader = command.ExecuteReader())
                        while(reader.Read())
                            Subscription thissub = new Subscription();
                            thissub.SubID = (int)reader[0];
                            thissub.Title = (string)reader[1];
                            subs.Add(thissub);
                string output = new JavaScriptSerializer().Serialize(subs);
                return output;
    I have the following AngularJS resource calling it, saved in the App_Plugins folder:
    angular.module('umbraco.resources').factory('SubscriptionPickerResource',
        function ($q, $http) {
            return {
                getAll: function () {
                    return $http.get("backoffice/My/SubscriptionPickerApi/GetAll/");
    My site runs over HTTPS. I have a redirect setup in IIS to direct all traffic to HTTPS. the web.config setting 'UmbracoUseSSL' is set to true.
    I keep getting a 404 error. I have tried a bunch of different URL iterations, all come back 404. When I examine the request, I see the URL is 'https://mydomain.com/umbraco/backoffice/My/SubscriptionPickerApi/GetAll/'
    What am I doing wrong?
    Jul 29, 2022 @ 21:11
    Ross Ekberg
    Anyone?
    Aug 02, 2022 @ 14:04
    Ross Ekberg
    Bueller?
