I can't figure out what's wrong. The site is Umbraco version 8.17.0 and I have an 8.11.0 site with the exact same form setup that displays errors properly. Is there something in the later Umbraco 8 versions that might be causing a problem?
I'd check to verify that you have the associated/required scripts loading:
in 8.6.0+ it's as simple as the following
@Html.RenderUmbracoFormDependencies()
This will then output the aspnet-validation js which is likely the missing piece.
Hi, thanks for your response. But this isn't an Umbraco Forms form, just a standard/simple MVC form. It's just that the only difference between this form on my 8.17.0 site and the working form on my 8.11.0 site is the Umbraco version, so I was wondering if there were settings changed between versions that could be disrupting the verification.
Could the associated scripts still be the problem? And if so, how do I check this without needing the Umbraco Forms code?
EDIT: It was indeed a script issue, even for a non-Umbraco Forms setup.
Validation/Error messages not displaying for basic MVC forms
Submitting a form with required fields empty fails to submit, but also fails to display errors.
Form's model has pretty standard setup for each field, example:
The errors are supposed to display within a div above the form:
I'd check to verify that you have the associated/required scripts loading: in 8.6.0+ it's as simple as the following
@Html.RenderUmbracoFormDependencies()This will then output the aspnet-validation js which is likely the missing piece.
More info from the Umbraco docs: https://our.umbraco.com/Documentation/Add-ons/UmbracoForms/Developer/Prepping-Frontend/index-v7#umbraco-forms-version-860
hope this helps!
